Good morning, I have a couple of final xa 160.5, a friend tells me that often feels more 'strong on one side (left) so I wonder could be the pre (XP20) or the bias of the end?? I ask you can control the bias of xa 160.5? how do you '??
First I'd check to see if there are any architectural acoustic features in your room that may cause the image to shift to the left?
swap places of input cables on amp input , or preamp output
if weaker side change th eplace - something is upstream of amp (then repeat swapping between preamp and source )
if weaker side stay in place , then repeat swapping of cables (side) between amp and speakers
little use of logic can't harm 😉
