Hi everyone.
I'd like some information about the ending being discussed.
I have the aforementioned final pass x 150.8 and I would like to pilot the MG 3.7 magneplanars.
as these isodynamic speakers drop down to 2 ohms (and on the technical characteristics of the passage x 150.8 I find nothing about loads below 4 ohms) I would like to know if such a load can be difficult for the final. Finally I would like to know if the power is sufficient for the type of speaker.
Thanks and sorry my english.
Papa or Wayne will give you competent reply
If you not get reply in few days, send an email to Pass Labs directly
X150.8 is rated at 20 amp output per channel, which is about 800W peak into 2 ohms.
Somewhere above that it will shut off, but I don't think you will encounter that.
Pass Amps are magic with Magnepan speakers. This is a special combo if you have ever heard this set-up, especially with the inexpensive Mogami interconnects and speaker wire. Magnepan factory has a Pass amp as a house amp.
