Selling a NP D1V33 including the case, only high-quality components were used, the clone DAC works, this was developed by Spencer using 4x PCM63PK, PMD100 to SM5842 converter. Spencer (FET Audio) did this D1 clone a while back. I can provide the Diagrams for the NP D1 DAC clone (enhancement)
I had this running for a few years. But I switched from the balanced signal chain to single ended and have no use for the DAC anymore. I can also add the CS8414 receiver and the SM5842APT that I used before the PMD100. The D1V33 DAC is delivered with the Aluminum Case from Schroff (hight:110mm, deep: 320mm, wide: 430mm Front:485mm) as shown in the pictures but without the two transformers.
If anyone needs pictures, I can send them by email.
Following two Transformers needed with min specs. 2 x 9V/30Va and 1 x 18V/30Va
The DAC is located in the EU, I would prefer to sell it within Europe, but other Countries is possible as well.
The price I’m asking is 400€ plus shipping with DHL and 5% PayPal fees.
Hi Spencer:
A few questions if I may please.
Is this still available? If not, do you have another that you would be interested in selling?
When you say enhancement, do you mean that it is an enhancement over the Pass D1? I ask because I am familiar with the Pass D1 as I own one.
When you say that it D1V33, is that your latest version?
You say: Following two Transformers needed with min specs. 2 x 9V/30Va and 1 x 18V/30Va. Would I have to install those or could you do that for me? I could of course pay for that.
I live in the US so checking if it would work at US 110v AC?
I can email you separately if that is easier with more details.
Thank you
Thank you
My mistake and thanks for the correction. US standard voltage is what I need. I see that it is indeed 120 volts here in NYC although there can be some fluctuation around that.
I now realize I made additional errors in my post. I realize now that I am writing to @finwbu not Spencer at FET Audio. My apologies again, @finwbu. And are you able to help with any of my questions? I could be interested in your unit if it works for my needs. Or perhaps I should write to Spencer?
Walter, maybe you do not want to post your email address openly. It may attract undesired attention.
