I just got my mosfet citation 12 clone working after some trouble with dc offet prolly caused by the wrong transistors.
2N3904/6 were the closest i had to the MPSL01/51, hfe pretty much the same.
Here are a few pics:
And no that opamp is not part of the circuit, i just dident bother with desoldering it before using the board.
Yes i have, it gos to the positive rail with a resulting bang from the speaker.
Schematic:
Heres a vid of this amplifier in action: YouTube - MosFet Citation 12 by Nelson Pass
Schematic:
There is another thing i am considering, replacing the 18k resistor on the input stage with a current source. Not sure if that would make a difference tho.
If it posed a significant difference in performance, i think pass would have included it in shcematic, unless he just did the mods the board allowed for.
What do you guys think, would a current source in place of the 18k resistor do any significant difference or would it just be a waste of time ?
I don't have the equipment to measure the difference if any, but i may try it just for fun.
Heres my proposal:
I've also ordered 4 of these fets to test out:
http://jm.plantefeve.pagesperso-orange.fr/acd100nsd.pdf
If your PS voltage is +/-35V (as the sch. shows) then you have a bit less than 1mA through each LTP transistor when you use 18k to supply the LTP.
With CCS (as you drew it in post #13 - red LED and 330R) there will be about 1.5mA through each transistor in LTP and that changes everything. Put a trim-pot across the R8 (330R in your sch.) in order to adjust the current through LTP and that will settle working points in the amp.
Im not gonna mess with it anymore, ...
That's a good strategy: run away quickly from everything that doesn't work first time !
- Pass mosfet citation 12 clone
