pass labs x2-1
Original
Hola Miguel,
Just leave it like ZM said they look original to me.
The only thing I would have done differently is put a (isolating) sleeve over the leads of the components but nevertheless it'll still work if you don't touch them.
I urge you to test the whole amp by using the schematic you send me and if everything is OK than you need to go deeper in to troubleshooting cause by replacing the (damaged) parts alone and not getting the amp to sound good you will be needing a helping hand from a friend who can fix it for you.
Again, it's not difficult to do this and with proper explanation you'll be able to fix it.
Now a question in Spain for you: Tienes el ruido o soplo en anbos vocinas o solamente en uno de los dos?
Do you hear the noise in both speakers or just one?
Gracias, Thanks,
Audiofanatic 🙂
the elna are superb quality, especially for the money and if you contact them directly you can customise the stops and switching behaviour. if you want to bling it up, find the positions you use most often and replace the smd resistor with ASMP texas components naked Zfoil SMD resistor. its better than DACT imo but similar to some DACT models, maybe even manufactured for DACT
because there may be blowing or background noise in the preamp at low volume?
Since I can only change the IRF610 which incidentally are heated much 3.3K resistors, out of print for any use which has, I could help and not to do because the voltages are OK.
Greetings to all.
this is third thread you're opening for same preamp with same problems .
conclusion - either we aren't capable to help you because of language barrier , or you aren't good enough in electronic to repair it even with our help ;
take that jewel to someone who knows what to do
pass labas x2-1
thanks for answering me and tell me that no repair.
I still have the problem of heating-R401 R301-R302-R402 and the measures are on its banks, the problem is that you have background hiss
low volume, you should change the IRF610?
THANKS
