i do some more test and I don’t think is transistor , it might be 2 leg components in SOT-23 package . I wish some here can help me out
Contact Kent we may have a completed and tested board available. I know we still have all the parts available.
You want the correct part for channel matching.
Hi mr wayne thanks For the reply And appreciate it, I just wanna know what is q3 , And what is the Part number . On My board only q3 is faulty
The NPN transistors are MUN2216 the PNP are MUN2115. So you need an MUN2216.
These are available from several manufacturers via Digikey or Mouser.
Mr. Wayne, I don’t know how to thank you. You really made my day and helped me a lot. Thank you again!🙏🙏🙏🙏
You’re welcome. Things do fail and it’s nice to be able to fix them.
Apparently available in 6 different SMD case styles (sizes) according to the datasheet from On Semi, so you will need to be sure to get the correct part.The NPN transistors are MUN2216 the PNP are MUN2115. So you need an MUN2216.
I’ve already received the transistor and replaced it. It’s working fine now—thanks again!
- Pass Labs X1 volume control problem
