So Innerfidelity seems to have announced a Pass Labs headphone amp to be released in a few months.
https://twitter.com/InnerFidelity/status/553661955031199744
Consider me excited 😀
considering power requirements , that one could be called ZM Loudspeaker Amp ....... or ZM Short Circuit Between the Ears , when used for cans
Zen Mod
........look at all those heat sinks, which are about to get bigger.
I'm seeing enormously lesser than optimal number of LEDs on pcb ;
everyone knows that proper drek must have at least 6/channel
that's at least how we do in OPLDF
Pass Labs not only launched headphones at CES 2015:
Pass Labs INT-60 & INT-250 Integrated Plus Xs Phono Pre & Headphone Amplifier
Pass Labs just launched their new INT-60 and INT-250 integrated amplifiers plus the Xs Phono Preamplifier and Headphone amplifier.
The INT-60 and INT-250 ($9000 and $12000) integrated amplifiers utilize the same advanced circuitry of the Pass Labs' Point 8 amps. This includes their innovative power supply and output stages. Digital level display and the iconic glowing meter, as found on Point 8 amplifiers, are also found within these new units.
Pass Labs' Xs Phono Preamplifier ($45000) employs a dual mono power supply and has three inputs. All loadings can be saved to memory for each input. Internally, there are six ceramic input boards and two ceramic gain modules to ensure the highest of sound quality.
The Pass Headphone amplifier ($3500) has two unbalanced RCA and an option of headphone or pre-amp outputs. Innovative Pass Labs' Class A circuitry uses MOSFET devices for outputs and amplification is of a low feedback design. Pass Labs Headphone amplifier is designed to drive impedances from 20 Ohms on up. A custom over-designed toroidal power transformer with Faraday shield ensures there is an abundance of electrical power, yet minimizes any noise reaching the critical analog stages. This low noise power supply with discreet regulators has over 40,000 uF of capacitance.
- Pass Labs Headphone Amp
