Pass D1 output stage.
Some one knows if it is possible to apply the output stage of the Pass D1 to a CD player that it uses 4 BB pcm1702 in place of the BB pcm63?
The only difference between two me seems to be the output current that is 1,2 mA in place of 2 mA.
Thanks.
Thanks guys.
To this point, if not mistake, task that they go replaced in agreement also cap.C15 and C16.
Still a question.
Thoughts that replacing ghi IRF 610 with of the MPV3306, or the 2sk389 can go the same one well? I ask, why of these transistors I have some in house already of the selected braces, therefore I would avoid to buy of others.
Thanks again.
pro said:
Thanks guys.
Still a question.
Thanks again.
Oups ! Yes you're right, I just forgot about the LP filter.. Just recompute the cap's values accordingly 😉
Don't know the MPV3306. Same as Zetex' ZVN3306 ? If yes, it should work, but be careful about dissipation issues. I don't know either how it will sound with a 3306... Just test.
2SK289 should work too, but chose the right grade to withstand the bias current. In this case the gate voltage should be negative to achieve 0V at the source. Just check this thread for additionnal info :
http://www.diyaudio.com/forums/showthread.php?s=&threadid=34191
Hope this helps
The original D1 stage has a volume control between drains of Q3 and Q6 . I made a volume control by a chain of resistors 80R/160R/320R/640R/1,24k/2,49k/4,99k/10k each resistor with one relais that bypasses it when on.
Why is this volume control at the Drains of Q3/Q6 and what would be disadvantage to put it between the sources of Q2/Q5?
If i want more voltage, what about instead of Q2/Q5 source follower pair a differential pair like BZLS around Q3/Q6 ?
or would it be better to double all resistor values and use +-60V with the original circuit?
I was looking for more voltage too.
I just tried - 2 days - the folded cascode , see the SuperSymmetry patent at
passlabs.com , and I am particulary enthusiast with the results , and more pleased than the source follower. I was suspecting that these dacs - 1541A in the case - was , soundwise , in need of more voltage swing and by listening it seems a correct finding.
I made it with ZVP3306A P-channel mosfet .Of course after the folded cascode is possible apply the buffer too.
Another BOSOZ gain stage is not going to deliver what you search for - probably.
Hi Stefano.
Have you a schematic for the 1541 D1 stage?
Actually I use passive I/V with a simple diy opamp made with a 2sk389 cascoded with 2n5486 and CCS always with 2n5486. The current is given by a zvn3306a with CCs 2n5486.
The all it seems to play much soft one and detailed at the same time.
I would like to try the active I/V.
pro said:
Hi Stefano.
I did not enjoy too much the passive I/V especially in the 1541A , a matter of taste , maybe .
I am enjoying the folded cascode a lot , instead . Spectacular , absolutely .😉
I used the D1 DAC I/V stage on the PCM chip with the original resistors and caps. The output level is only a little lower than my cd player so I didn´t make any changes. I don´t have balanced out so I didn´t use the volume control that Nelson Pass has in the circuit.
Hi averybody.
I got it.
This is the folded cascode I/V with Zetec fets for my NONOS Philips CD582.
It seems to sound very dinamic with high frequency very smooth, deep and large soundstage. Really impresive.
The L/P filter is a second order and the two black tubes are full up aof silicon grease, so to stop the oscillation around the 0V of the folder fet.
Ciao.
