Pass B1 Buffer
So I'm interested in building a B1 Buffer and using the PCB.
I'd build the buffer and not use the source 1 / 2 select. This would be pretty simple with just 2 jumpers in the PCB force the PCB to only use the input 1.
The volume piece I'm not sure what I'd do to bypass the volume pot/attenuator. Each channel on the PCB for the Pot/Attenuator has a "CCW", "W" and "CW" to connect to the Pot/Attenuator. I'm guessing a jumper introduced to this area would pass the signal in full.
