If the input impedance to the Class D is high then it should be fine.
Actually, it probably will be fine anyway.
I have strong feeling that it's possible without flaws , but to be sure - you need to clarify few common things ....... plugging in usually means connecting source in/to input , while ..........
so , be precise please , just that we can be sure which is exact level of mix-up ........ just words , or both words and facts
I often think when i write my questions or answers...
will i be understood 😛
Ahm... so connect is maybe better... connect the alephJ and an other power amp to the aleph p
I thought about biamping, driving my shelf Speaker via the alephJ and support them with 2 active Subs, at frequencys where they running out of steam.
I would avoid an active crossover after the pre if this is possible and go direct into the amps.
The aleph via XLR and one activesub per side, via cinch.
even if you wasn't precise again ........ it'll work
I wrote about mix-up like that some time ago - either in
or PSM LS Cook Book (too old to remember , too young to check
