I am building a second SSE that I can use to test whether or not I can hear the difference between various components -- mostly the coupling caps and cathode resistors. I seem to recall one of George's test rigs having a screw-in holder soldered into the pcb in place the cathode resistor to make swapping quick and easy -- any idea what that part is called? Havent been able to figure it out on Mouser or Digikey.
Alternatively I thought I might put in a 5 position switch to be able to quickly flip between different coupling capacitors since I am not sure I could remember the subtle differences if i had to shutdown and swap parts. I am a little worried about leaving multiple charged capacitors disconnected from the circuit though.
Thanks for any help.
Allen
Allen
