Parts question
They appear to be the same basic part.
One problem that I've found with a few of the Philips transistors is that they plastic they use melts easily. For example, you can heat 2 legs and lift them for testing with most SOT-23 transistors but some of the Philips just turn to goo when you try that. They use the same plastic on some of their TO-92 transistors as well.
I don't know why you're interested in using them unless you found them for cheap somewhere. I typically use the MMBTA06/56 as subs for those in Rockford amps.
I've never had a problem with philips parts except for what I described. They will probably be OK as long as you know that they're from a reputable distributor. I don't use enough of anything to buy in that quantity. I buy in 500pc quantities (A06/56) and that typically lasts me 3-4 years.
Yes I understand what you are saying. I have enough already to last me 10 years probably, I just hate passing up good deals. They are from a reputable distributor which I have purchased many parts from in the past.
I will think on it.
