can't seem to edit part2 but here's additional info
chipamp PCB lm3875 sold
Toshiba 3960 sold
and Magnavox CD2000 plays CDRs!
New and unused Parts for sale – shipped prices (minimum $10) to Conus only. All are from non-fake sources and are leftover new ones (ones I used (not listed here) were to evaluate whether to get into the audio business when I worked at a chip company a while back.
LM1875 sleeve of 6, $12 or $4 each
LM3875TF sealed bag of 5 $60, sleeve of 5 $55, sleeve of 3 $32, or $12 each bag & 3 sold
LM3886TF sleeve of 5 $25, or $7 each
Lm4780 exactly one - $16.
PGA2310PA, have 5 in a sealed bag $65, or $20 each.
88+ Old high voltage caps for those that need more than 400v. SOLD
$20+US priority mail medium flat rate box $13.45 (too large to fit small FR)
.0001/600*12, .001/1600*4, .0015/1600*4, .002/1600, .002/2000*8
.0047/2000*6, .007/1600*5, .02/1600*10, .025/2000, .027/2000*5
.03/1600*6, .036/2000*5, .039/2000*5, .05/1600*3, .068/600*12, .075/600*6
Cement high wattage resistors – 51 total – 11 used (short leads or solder on end) SOLD
1 pound 8 ounces, $10 plus (shipped US continental via small flat rate box for) $6.80
10K/10W*5/4U, 20K/10W*2, 3.3/15W, 3.3/10W*2, 5/10W*5/1U,
2K/10W*1U, 5K/10W*4/1U, 120/5W, 120/10W*5, 2.7K/10W*2/1U
4/20W*2, 1K/10W, 56/10W*2, 500/5W*8, 2.2K/10W*2/1U, 50/10W*4/2U
750/10W, 40/10W, 10/5W*3
Two kit sets of resistors from a long time ago.
My best guess: Dale, precision, pre-EIA values, 1 watt, 1% (considering some
are only 1R apart), probably MILITARY use since I have never seen these in
any commercial units in my lifetime.
You can see where I have used these (less than 10 in kit2), for exact voltages
in tube power supplies instead of using 1K when it needs a 1.18K, replacing
hum pots with exact values to prevent point contact corrosion, and exact F3
calculations when the caps are restricted to EIA values, and creating exact
combinations for resistance AND power without compromise.
Kit1 61 values, 10 per value -------$61+ 6.80 USPS priority mail us continental SOLD
24.9,26.3, 28.7, 31.6, 38.3, 47.5, 62, 63.4, 68.1, 69.8
75, 88.1, 113, 137, 169, 174, 182, 205, 267, 294,
300, 301, 324, 422, 549, 649, 681, 698, 715, 787,
806, 1.18k, 1.21k, 1.61k, 1.68k, 1.78k, 2.26k, 2.61k, 2.67k, 2.86k,
2.94k, 3k, 3.57k, 4.12k, 5.47k, 6.15k, 6.49k, 6.61k, 6.98k, 7.15k,
7.68k, 21.5k, 23.6k, 28.7k, 34.5k, 82.5k, 140k, 162k, 472k, 1.33m
21.5
Kit2 60 values, 500+ resistors, $50+6.80 shipping priority mail US continental
47.5*8, 62*10, 63.4*10, 64.9*4, 69.8*10, 72*1, 75*10, 88.1*10, 113*10, 137*10
169*10, 174*10, 182*10, 205*3, 221*8, 267*9, 300*8, 301*10, 324*10, 365*5,
422*5, 549*9, 649*10, 681*12, 698*9, 715*10, 787*10, 806*10, 1.18k*5, 1.21K*9,
1.61k*10, 1.68K*10, 1.78K*10, 2.26K*9, 2.31K*5, 2.61k*10, 2.67k*10, 2.86K*5, 3K*2, 3.57K*10,
4.12K*10, 5.47K*9, 6.49K*10, 6.61k*10, 6.78K*3, 6.79K*8, 6.98K*10, 7.15K*10, 7.68K*10, 13.27K*6,
15K*7, 21.5k*20, 23.6k*10, 28.7K*10, 34.5k*7, 82.5k*6, 140k*10, 162k*10, 472k*9, 1.33M*10
ST70 Board – computer layout with complete set of parts. $50 plus $13.45 priority mail to CONUS.
6GH8 tubes – 7 NOS
Compactron kit –see Thomas Meyer, Vinylsavor on his 6GE5 amp. He charges almost 900 euros. I ask for $75. SOLD
All parts new except as noted - Includes 2 6AC10 (triple triode compactron), 2 6GE5 power tube, 1 5U4 rectifier, sockets for all. Also includes two used but healthy transformers for B+ (use for testing since they may or may not supply enough current), two SE output transformers. All you need is a 5V and 6/12v transformer for the rectifier filament and for the compactron heaters (and maybe a b+ supply in which case you can add the 5 and 6.3v heater windings) (and of course, case and design). Please add 13.45 for priority mail shipping to CONUS.
5702 subminiature tubes – lot of 100. Great for experimentation at $1 each – use 3 or 4 in parallel to lower noise floor. $100 shipped priority mail to CONUS. PM for pix
6832 subminiature tubes – lot of 100 - $200 shipped CONUS
CE mfg – 40/20/20/20 at 525V, rubycon 20/20/20/20 at 450V, two JJ 50+50 at 500v
4 can caps total complete with four mounting brackets. $100 + priority mail shipping
(due to size – can’t fit in smaller box and costs lots more! For parcel post) of 13.45 CONUS.
Will throw in two bonus GIANT caps of over 1000 UF and unknown voltage but probably
over 350-400V – Do reform these puppies. The multi-section caps are great for repairing old tube
Dynacos, Fishers, etc and at higher voltages than original for protection
part 2 coming up
Toshiba 3960 sold
21.5
6GH8 tubes – 7 NOS
part 2 coming up
part2
Chipamp LM3875 PCB - $20 shipped Conus. See all the way above if you need LM3875s.
Two 9-pin tube test PCB (labelled CK27) - $10 for both shipped conus
Bas Horneman 8-pin tube rectifier bare board for use in Aikido circuits – 4 available - $10 each shipped conus
Power supply board – seems to have dual (plus, minus) VR. Seems to have a second set of diodes. 4 available (no parts –you supply) - $10 each shipped conus.
Bias board for St70 or Mark III (one only) – uses zeners to ceiling the voltage, with all parts for
either ST70 or Mark III. $20 shipped conus.
For modders – golden oldie blast from the past - Toshiba 3960 – March 2004
(yes, it’s before the June 2004 magic changeover date). This was infrequently used
as a DVD player and I now have too many real CD players to fix. Great for
Vinnie and Swenson mods now that the Blackgate madness is over. $25 + $15 shipping CONUS
Another Cd player – Magnavox CD2000 with legendary TDA1543 (the one that Peter Daniels likes)
CD Player. $20 + $20 shipping CONUS. Will include list of relevant 1543 mod links.
thanks for looking.
thanks for looking.
