......Many years ago I got a transformer custom built by a guy in the lane that leads to the station (sorry I don't remember the name). It was very well done. If you can find the shop, I heartily recommend him.
Most probably the name of the shop is "Tomson Transformers" just near the bridge after remote control shop.
Grounding belly band
The copper is connected to pin17 and is grounded at the transformer pin(center tap) pin12.
Gajanan Phadte
Gajanan Phadte
Error correction...
through a capacitor of 0.1 mcF
Gajanan Phadte
Gajanan Phadte
Gajanan, this is very interesting and thank you for exposing the truth to us.
I will definitely shield transformers in this way in the future.
Roushon.
Roushon.
FR4, 35micron(1oz) glass epoxy copper clad board
If it interests you, a source of FR4, 35micron(1oz) glass epoxy copper clad
board.
FR4 Copper Clad Circuit Board DOUBLE 2 Side 30x30CM PCB | eBay
Roushon
board.
Roushon
Idhar yehi hota hai
Har baar ek bakra kato,
aur katneko hai karodo
Gajanan Phadte
u right sir
Finding coper sheet for belly band may not be easy...
but finding a copper pipe used in airconditioners may be very easy. Bigger diameter is better.
For making belly band out of copper, cut this pipe length wise and flaten it.
Gajanan Phadte
Gajanan Phadte
Suggest you visit the metal market where they sell metal sheets in retail , bare wires etc. They all seem to have thin copper sheets here. However the copper band is used only as an electrostatic shield. The inner non closed band between primary and secondary would effectively reduce noise coming in from the mains side. It will need to be connected to the ground scheme.
Do you guys really have so much trouble with noise on the mains ? Unless you are just trying to make the ultimate supply !
Where are you located ? Copper sheet is a standard product. You can buy it from the metals market, or you can buy it from the guys who supply the motor/transformer rewinding industry.
I don't understand why people are having trouble buying copper sheet.
That is because every one is trying to find it in diyaudio.com 🙂. One has to hit
the road which I am going to do in a couple of weeks and then post here the
address, telephone of the retailer....
Roushon.
I am from Goa and I can get all the brands(in the world) of liquors only. Rest all is 100s of kms away.
Anyhow, I just showed an easy place to get a copper sheet. I don't need any. Thanks for the help anyway.
Gajanan Phadte
Surprise info: Finding the enamelled wire is also a nightmare here...
Gajanan Phadte
dear roushan ji,Gajanan, this is very interesting and thank you for exposing the truth to us.
Roushon.
where can i get photo resist paper to draw pcb print.thanks
I got SMD part from lamington road min qty 100 for resistors , capacitors Size: 0850 resistors qty-100 Rs. 25-30 (depends on the tolerence) capacitors qty-100 Rs.50-100 (depends on the value) ATmega16A qty-1 Rs. 150 Max232 IC qty-1 Rs. 40 (not very entertaining to hobbyist and student but few retailers for smd components you can find) SMD ELECTRO COMPONENTS 54-C Proctor Road , Jyoti Estate, Near Parijat Bldg , Off laminton Road Mumbai - 400 007 Tel - 5658 6555 mobile : 93242 11912 Email : smdelectro@gmail.com
Thank you very much for your post. It is exactly the
time I am looking for SMD and was thinking of searching
in LR, already asked Visha who did not have. Thanks
again for the definite source.
Roushon.
dear roushan ji,
Dear Masood,
I know you are looking for this for at least
two years now in this forum. I already told you before that
I use toner transfer method and have no idea about photo
resist method. You can ask Viki.
Best wishes
Roushon.
Many have tried ordinary thin paper as found in catalogues. Try some papers of different types. Who knows you might get lucky and we all can benefit from it.
You might need to touch up the gaps...try bow pen with enamel paint. Some prefer nail polish as it dries quickly.
Gajanan Phadte
Gajanan Phadte
- Design & Build
- Parts
- Parts in Mumbai (India)
