Also missing two D9 and two D10 zenners.
What value and current rating are they supposed to be as I might have some allready.
Kram
Kram
Coulomb said:
Did you get your new shipment already Stan??
Are you going to send Kram 2 caps?
Anthony
Haven't gotten it yet, any day I'm sure. No problem with sending my two left over 1000uf to Kram if he needs them.
Best
Kram said:My damaged caps are black, have 3 legs and are made by elna. Are we talking about the same ones?
Hi Kram, the 2 caps I have available are 'blue plastic covers' BC 1000uF/100V these are the power supply caps that combine w/ the 3900uF/100V that came w/ my kit.
Stan
I will take the spare caps that you have, let me know the postage costs and I can paypal you.
The caps that were damaged are supposed to go on the preamps pcb not the power supply but aslong as they are 100v and 1000uF they will work.
Here is coulombs pcb parts with the black caps on the pcb
http://www.briangt.com/gallery/album12/DSC00422
Forgot, sklimek if you could email me the price of postage I will email you back with my address.
Mark
Mark
Kram said:I will take the spare caps that you have, let me know the postage costs and I can paypal you.
Mark
Hi Kram -
just sent you an email...
Edit:
I seem to be having email problems, let me know if you received my email...
Hello sklimek,
I got your email and have replied, hope it reaches you.
Mark
Edit. Also sent to different address shown below.
Mark.
Mark
Mark.
Kram,
I guess when it rains it pours - Definitely having email issues - send your address to here, I'll be able to read it on my wifes computer later, sorry.
pb0094@hotmail.com
Stan
pb0094@hotmail.com
Stan
Ok I found the BOM for the power supply and it seems that D9 and D10 should be 4.5V zenners. Is this correct?
Also just to further my knowledge, how do you read the number on the side of a zenner diode and come up with its value.
The two types of zenner supplied in my kit have the following numbers on them:
1N4739A and 1N5230B, how do you get a value from these?
Mark
Mark
Hi Mark,
D9, D10 are both diodes, they are not zener diodes.
You can use the 1N4947.
Don't forget the correction on D9 and D10.
http://www.diyaudio.com/forums/showthread.php?postid=701869#post701869
Kram said:Ok I found the BOM for the power supply and it seems that D9 and D10 should be 4.5V zenners. Is this correct?
Mark
!N4739A
!N5230B
Did you need some replacement patrs Kram?
Anthony
Thanks for the replies guys.
jajabin, are you sure that D9 and D10 are Diodes and not zenners. The BOM here says otherwise http://www.diyaudio.com/forums/showthread.php?postid=638685#post638685
and so does this page http://www.diyaudio.com/forums/showthread.php?postid=701869#post701869
Coulomb, thanks for the links.
I thought the code on the zenners had a direct relation to its value. I have had others that did. Anyway thanks.
sklimek is sorting me out with two new caps, though they are a different make it shouldnt make any difference.
Mark
Mark
Kram said:Thanks for the replies guys.
Mark
OK Mark, if you are missing any diodes I can send you a few replacements. If you want all four of your Preamp Caps to match, let me know and I can see what I can send you.
Anthony
Hello,
I dont think I need any more parts sending, I should have some 9.1v zenners and sklimek has allready posted some caps to me. Although it would be nice to have 4 caps that are all the same.
In order to get 4 of the same caps you (Coulomb) could either send me 2 of the Elna caps (black) that can be seen here i think http://www.briangt.com/gallery/album12/DSC00420
or send me 2 of the ones that sklimek is sending me, I dont know what they are though.
Mark
Mark
Kram said:Hello,
Mark
HI, they're BC 1000uF/100V blue plastic case, they will drop right into C2 and C3 on the amp board. 1.50 inch high and same pin spaceing and can diameter.
They came w/ my kit in the psu filter cap bag which had 4 1000uF/100V and 4 3900uF/100V. One was damaged so I opted to get 4 more of the 3900uF instead of the 1000uf and make the power supply 4-up of the 3900uF/100V... my parts bags seem to be different than yours in that I do not have any Elna caps just Nichicon and BC - Hope they work for you - Stan
sklimek
I am sure they will be fine, and many thanks for taking the trouble to send them and not charging for the postage.
Mark
Mark
Some of the parts bags were a little different due to parts availability. I am still waiting for some parts promised me by a supplier who short shipped me to finish 4 more kits.
Anthony
Anthony
Can anyone confirm the value of zenners D9 and D10.
Karis BOM indicates 4.5v and the schematic jajabin linked to indicates 9.1v. which is it???
- Group Buys
- Parts GB for X-BOSOZ (KARI's Boards)
