Parts availability
Hello all, apologies if this is a well known topic/answer.
I am beginning to put together my parts for an SSE kit and I notice that many of the first few parts I am searching for are obsolete. Is there an updated list of some sort? What is the expectation here? Do I just find an equivalent on my own, or is there a recommended process? Thank you for your time, this is my first audio kit of this nature.
The passive components (resistors,capacitors) are just to search for the same rating, dissipation for resistors and peak voltage for capacitors.
Which site are you using to source your parts, and which parts are problematic ?
Thank you.
I have been using the sites on the worksheet, mouser and digikey, and looking up the part numbers provided. I only got a few parts deep from the top and the majority of them were obsolete, so I figured I would ask before I went further.
Digikey lists available substitutes for many obsolete parts:
