Parrarel opa1622 amp
I have an opa1622 evm board and really like it so i try to make a better headphone amp using opa1622. Inspire by the design of agdr, i come up with this but when i simulate the open loop gain for stability, it look incredibly unstable. The Aol*Beta ( pink line) cross 0db at phase margin <0. I need some advice on this, thanks.
I don’t follow your schematic if are trying to parallel it. Here’s what I did with the OPa1688 and it works great. I have a new parallel 8 OPA1622 in the works - boards fabricated but not populated yet using same topology. You want an opamp to do voltage gain first then use parallel amps in buffer setup with 0dB gain. Have global feedback after the parallel buffers back to input stage.
http://www.diyaudio.com/forums/head...pa1688-low-thd-muscle-amp-10.html#post5494197
Like this:
attachment.php
I want to have some gain so i can add compensation network.
