Parasound Zamp v1 Relay clicking in and out
Joined 2013
I recently moved so I pulled this back out of the closet to see if I can get this running for an office system.
Issue - with a DBT the relay would click in and out every 1/2 second, due to DC on the speakers. I tried with 25, 40 and 60w bulbs and the only difference is the speed of the clicking and with a 60w bulb the power transistors would start to heat up. I found a faulty B817 power transistor and changed all of them for similarly matched Hfe 2SC3519A and 2SA1386A, which seem to match pretty well. Still wasn’t working and I had to move.
Ahead 8 months – and I’m trying to revive this little amp
First thing I did was pull all the transistors and test with a DMM and a transistor tester (from eBay) and only found one bad small signal transistor (Q202) and replaced it with a suitable replacement I had on hand (orig. c639, replaced with a leg-adj., and reversed C2240) for now and will get a correct one once it is back running.
I put all the small-signal transistors back in the PCB, but left out the driver/power transistors to do some testing.
Issue without the power transistors installed -
Left channel 220r resistors (R225/R227) in-front of 0.22r emitter resistors are getting quite hot - small amount of smoke with a 60w bulb in the DBT. Right channel has no heat on those same resistors.
I took some voltage readings and show ~24vDC on those resistors (w 25w DBT in place).
I included a picture with voltages taken with the black DMM lead on the black speaker connector and probing with the red lead (again with 25w DBT in place) ~24vDC on the Collector and -23vDC on the Emitter of the power transistors, but when the relays clicks out of circuit (takes 5-6 minutes with the Power Transistors removed) I get -5vAC on the Base and Emitter, but still have 24vDC on the Collector. Not sure what that tells me/you if anything.
If AC is getting through, does that mean a Capacitor is bad? I get voltage leaking across C207 and C209, which appear to be 47pF and a 33pF. The electrolytics look OK, no bulging or leaking, and the two I pulled tested within spec, but I haven't tested all of them out of circuit.
I don't have, and cannot find a schematic - so I'm a little lost on verifying resistor values and mainly checked for reasonableness (channel to channel) and that none were OL, and I have not found any that seem out of spec.
Joined 2013
Well - I put the power transistors and the 669A (I think this controls bias) back on the heatsink after checking all components and re-soldering most of the small transistors.
But I have the same issue - relay clicking in and out. Interesting part is if I adjust the bias on the right channel, the DBT glows brighter and the relay clicks in-and-out faster and vice-versa if I turn it down.
The left channel does not change if I adjust the Left bias.
Heatsink does not get nearly as hot, even with a 60w bulb in the DBT?
I also can't get any valid voltages on the +12V, or +/-15 linear ICs, which previously they would go up, until the relay clicked out, then start from 0 and build back up until the relay clicks out again.
Starting to think I might be better off to just gut this and substitute a different amp board and use the case, psu and heatsink?
Joined 2013
Uploaded a picture with voltages for the driver and power transistors. Hoping someone can guide me where to look for the fault, because I have checked most of the resistors and transistors and can't find a bad part at this point.
Best way to approach things is with no power.
Test all the components best you can and see which ones are faulty.
I had a fault once where everything tested fine but amp didnt work right.
I then took out all transistors and checked them on a semiconductor analyser and the gain of one transistor was 1 !
Another time I couldn't find a fault after checking all components.
Turned out some !"£$%^ had tried to fix it before me and put in a wrong type transistor ! It was pnp instead of an npn and the number had worn off the transistor.
Joined 2013
Try a 100W bulb. With the lower wattage bulb you can get into a situation where the unit tries to turn on and draws current - The bulb gets brighter (and it's resistance increases) - the unit sees a low voltage and shuts down. Rinse/Repeat.
I may have forgot to mention I did try a 100w bulb and it has the same behavior. Just cycles the relay on and off and that left side gets hot.
Joined 2013
Good ideas so thanks. Without a schematic I have tested all the resistors and compared side to side for consistency. I also pulled all the transistors and tested with a meter, replacing the only one that showed out of spec. Also the relay since I had one on hand. Didn’t change anything.
I’m not sure if there is a good option since I can’t find a schematic and don’t know enough yet to trace the entire circuit.
Thanks for the insight, maybe I missed something and will catch it going back through the amp again more carefully.
