I have a Parasound that has developed a distorted output on its left channel. Any guesses as to what the problem may be before I open it up?
I'm guessing that maybe a Fet up chucked. I think it uses 2SJ115 and 2SK405 as drivers. Anyone know a source for these? They seem to be back ordered everywhere I look.
Thanks is advance.
Thanks is advance.
Parasound is running now.
What is the amplifier supposed to draw (amps) sitting at idle with no signal?
Any help here would be much appreciated. I think it runs class A for a few watts before switching to class AB.
Very nuch sounding amplifier and built like a tank.
Looks like I was a bit premature thinking I had it licked. It runs for a while and then the volume lowers somewhat on the left channel and gets distorted. It runs that way for about 30 seconds and then returns to normal. Watching a sine wave on the scope it looks normal. This happens when it is putting out around 6 watts and still in class A operation.
Any ideas?
Any ideas?
Have you vacuumed out the interior? That is what I would do at first and clean the input and output contacts. Next, I would 'exercise' the interior electronic connectors and use Deoxit or something similiar on them (with the unit UNPLUGGED FROM THE WALL, of course).
John
Thanks for the reply. I have checked the connections and cleaned the contacts with Deoxit 5. The problem however still exhists. Any ideas?
I'm not familiar with this model but if it has relays on the output you might try checking there. The problem I had with the one I was working on was 1). No audio or 2) distorted or low level.
This problem went away when I changed out the 2 relays that are located on the back panel.
- Parasound HCA-2000 Problem
