Parasound Halo Capacitor Help
Hi all, just have a quck question.
My Parasound went down (own 3 amps and all died within 2 months of each other) :( so, the main power cap in the Parasound is: input 100-240vac - 150uf 400v with extra values on the side (pic included) question is, I saw this cap on ebay: EPCOS Capacitor 150Uf 400V B43504A9157M
and
CAPACITOR, 150UF 400V
Capacitance: 150F
Capacitance Tolerance: 20%
Capacitor Terminals: Radial Leaded
Diameter: 22mm
ESR: 0.59ohm
Height: 40mm
Lead Spacing: 10mm
Life Time @ Temperature: 3000 hours @ 105C
Operating Temperature Range: -40C to +105C
SVHC: No SVHC (19-Dec-2011)
Voltage Rating: 400V
AC Ripple Current: 0.82A
Approval Category: IEC 384-4
Capacitor Mounting: Through Hole
External Length / Height: 40mm
Impedance: 730mohm
No. of Pins: 2
Operating Lifetime: 2000h
Operating Temperature Max: 105C
Operating Temperature Min: -40C
Ripple Current Temperature: 105C
Terminal Type: PCB Pins
Tolerance +: 20%
Tolerance -: 20%
Voltage Rating V DC: 400V
Would this be ok to use? As I do NOT! want to use some second rate cap, all I have seen has not got the extra values on the side and I sure do not want to damage my amp :(
PT-65C: MEAN WELL: Power Supplies & Wall Adapters I did a bit of digging around and found this AC power supply made by Mean well what the HALO C2's use, question is, again, they seem to be only around £11 odd for the whole thing. So, would it be worth buying a capacitor, seeing as this AC board seems to use only a specific type of capacitor, or just order the whole thing?
  • 216726.pdf
I tested them all, they read all of the uF readings correctly :) just the main one didn't, besides, I can't seem to find a single cap anywhere that can do these multiple voltages... Seeing as this whole new board is from 2013 odd, surely the caps even if they are made in Taiwan should be ok?
