I have purchased an Parasound A21 to run my Monitor Audio PL200 fronts and an A23 to run my Monitor Audio PLC150. I need some advice if I should bridge the A23 to run the centre channel. The PLC150 is rated as a 4 ohm speaker. The parasound manual says to do bridge a 4 ohm speaker. Is this correct? Am I supposed to leave the A23 in stereo mode and only hook up 1 channel. I am pretty green so please take it easy on an old guy🙂
Thanks for your reply John. My son mentioned the possibility of of using a y cable from the preamp and by amp the centre using both channels. What are your thought on this or is this evn an option.
