Paralleling two TDA7293 with balanced inputs
Joined 2011
Schematics is attached.
Gain of the first stage is 1.1 and gain of the TDA chip is 10.
Any comments are appreciated!
keep in mind minimum gain per datasheet is 26 (20-fold).
also I am not sure whether it's a good idea to use the TDA in "balanced" mode.
if you want to take advantage of balanced input (hi CMMR) an op-amp may be better suited for balanced-unbalanced conversion.
Reactions: pbilous
