parallel wiring 16 ohm 4 ohm
why?
is that mean that the 16 ohm subwoofer is useless?
my second subwoofer is (dvc) (4+4)ohm
what's is the best configuration for amplifier 4 channel (2,4,8)ohm capable
note: 2 channel is already occupied by 4 pioneer speaker
that is mean i wanna configuration for rest 2 channel
If your second subwoofer is DVC, then wire both coils in series, you'll get 8 ohms. Then ( 16 x 8 ) / ( 16 + 8 ) = 5.3 ohms
That way, your 16 ohms subwoofer will be more useful.
On the other hand, you'll be better to leave that 16 ohms subwoofer out of your system and wire your DVC subwoofer coils in parallel, so you'll get 2 ohms and get the most out of your amplifier.
What brand is the 16 ohms subwoofer? Subwoofers are mostly 8 ohms or less, unless it's a DVC 8+8 then you could wire it to get 4 ohms.
