ok I found this and it confirmed another members answer, it is the picture almost to the bottom oh and it is in Chinese so turn on translator. BTL ¿É²¢ÁªÇŽÓDIY TDA7492´ó¹¦ÂÊÊý×Ö¹¦·Å°å50*2 100W³¬TA202421-ÌÔ±¦Íø
when the Member emails me back with the final wiring for speaker and input I will post it,and I hope this helps the next person doing this.
Looking into this amp to use for a boombox but also interested in using it in a wireless monitor for karaoke. I know that the chip is already BTL and to combine the channels I simply make sure the input in the same (mono on both channels) and then tie both positives and negatives to the speaker(s). I know in normal (class ab) bridgeable amps you need to double the impedance to keep each channel at its original output but if I understand correctly in PBTL I want to halve the impedance to get the same output. Example, if amp did 25 wpc into 4 ohms in normal stereo I would have to use a 2 ohm load to achieve 50 watts in PBTL mode. Some versions of this amp being sold are listed to run on as little as 12 volts. I looked at a spec sheet for the chip and their test data graphs only went down to 15 volts. I estimate the amp will only do about 18 wpc at 4 ohms at 12 volts. will the amp run safely like this and I assume that would get me 36 watts in PBTL mode. Lastly, if running in PBTL mode and the inputs were just a stereo pair, what happens if there is no signal on one input and not the other? Thanks
Shouldn't the clocks be synchronised as well to avoid audible beat frequencies?
You can synch clocks or make them sufficiently different the beat is inaudible.
I read this in IR datasheet in regards to stereo irs2092 circuit.
