Dac
I am installing VCC-VDD supply caps at the bottom. But, unfortunately i was wrong and i could not make 4+4 monoural dac Do you have any idea how can i use one stereo dac as mono? If i am not wrong you did a similar dac with 7 TDA1541A. How can you describe it's sound? My dac especially in midrange and bass region is huge sounding. Very satisfied me. When i am comparing with my modified (non os + OPA627 installed) cd player, even comparision is not possible because their sounds are not in same ligue.
Noyan
Hi Bernhard,I like the layout with the receiver in the center, but the traces on the decoupling pins are unnecessary long. The caps could be much closer, traces much shorter and ground broader. No decoupling for the Vdd Vcc supply pins ?
Noyan
1. Not at -60dB level!!!
2. Not DR but SNR - at least not with only 16 bits!
1. -40...-80db
2. DR. 4x oversampling 16bits end quantization + 1st order noise shaping
Hi Bernhard,
Noyan
I'm not familiar with the TDA format anymore, best search the forum for glue logic.
