hi to all
can i use a pp ot with 5K plate to plate prim and 4-8 ohm sec.
for a parallel pp EL84 design
Push Pull amp with EL84 is 8K to 10K plate to plate load. So if you run parallel Push Pull with two tubes per side you will need to reduce the plate impedance by a factor of two. Therefore 4K to 5K P-P is proper load.
So yes. You can use a 5K p-p transformer for parallel push pull with EL84.
just have to finde me a good layout now
What kind of amp are you building? (musical instrument amp or HiFi)
