Is it possible to increase supply voltage and parallel 2 out stages per channel using the same Bias board? I have plenty of heat sink and just inherited a toroidal transformer that should give me 60V rails.
I have the BA3 and from what I have read I can parallel output stages and should be able to increase voltage. Can I use the same Bias board for two paralled output boards.
in case that mosfets are matched , you can parallel plethora of them
and I believe BA3FE will drive them pretty well
