Parallel Driver Tubes?
I got this little SE amp that has a 6L6 for power tube and 6SL7 for driver tube. Wired 100% parallel with the 6SL7 tube however is a 12AX7A. When I say 100% parallel I mean just that. All pins on the 6SL7 socket are directly connected to the corresponding pins on the 12AX7 socket.
What could be the purpose of this? I know that the 6SL7 and 12AX7 are almost identical electrically but what is the benefit/consequence of running in this configuration? Could it just have been to easily swap driver tubes between the 2 types?
The amp works fine and sounds great with just one of either driver tube at a time. When I plug in both drivers at the same time it sounds about the same but just a tad more open...maybe thats just me though.
Throw in your 2 cents I'd be delighted to hear it.
AFAIK, 6SL7 and 12AX7 are different enough that putting one section of a 6SL7 in parallel with one section of a 12AX7 could be a mismatch. The published data sheets for 6SL7 and 12AX7 have different spec for mu, or amplification factor: 70 for 6SL7, 100 for 12AX7. That right there would be enough to make me think they're different enough that you wouldn't want to do that.
