I'm guessing threadstarter is trying to make some kind of dual-mono supply without the additional transformer.
Although I'm not sure how having separate bridges will help apart from more capacity and better isolating between the two capacitor banks... wait... that's a good enough reason.
Some PC power supplies with multiple 12v rails have a separate rectifier and filter stage for each rail, but sharing the transformer. (The best ones have completely separate switching supplies for each rail, most simply have separate post-filters, and the cheapest ones lie and do not really have multiple rails.)
Many amps uses this type of separated PSU.
And it works quite well. Go with it, but remember to use lots of uF to get full benefit from this design
Sadly many manufactorers using this type of PSU claims that their amps are true mono build, even though the two channels shares the same transformer
- Power Supplies
- Parallel bridges?
