Just to be 100% certain, does the Paradise PCB include the shuntreg or do I need to order both boards?
There are three different choices:
Paradise R32b PCB € 11,00 per piece (€ 22,00 for a stereo set)
Shuntreg only € 8,00 per piece
Calvin Buffer € 4,00 per piece (€ 8,00 for a stereo set)
The Paradise PCB has the shunt regulator on board. But we thought it might be interesting to have that same shunt regulator available separately for other builds.
yuppie Paradise PCB whit separate PSU boards briliant idea I am going to get same eventualy
Actually, the paradise PCBs still contain the on-board shunt regulator, and for performance this is still the best solution. Any cable between the regulator and amplifier introduces additional impedance, which may not be helpful.
The separate shunt boards are for line stages, headphone amplifiers, your own phono (or microphone) preamps, or other stuff.
These separate boards have an additional connector for both plus and minus, which is called "sense". You can simply bridge to the output voltages right next to them (and this will be explained in detail in the assembly guide, no worries!!)
OR
you wire separate cables for the sense connections right to your amplifiers' supply connection - the regulator will then take that input as the real value, and regulate it. Depending on your setup this may lead to instabilities, so you should be careful when you attempt to do it, but again this will be explained in the assembly guide.
I may be repeating myself, but will their be any complete kits will all parts for assembly?
Not from me. But attached is the BOM for Mouser, that you can simply upload. It contains the parts for one channel (excluding the heatsink), so you will have to order these parts twice.
Thanks alot. Just what i needed! In that case i want to sign up for a stereo set, plus shipping to Denmark.
The EPCOS B32529C104K189 is not on stock. Lead time is set to 24weeks, any recommended replacement?
http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=4e874e0113
Put me down for four (4) each
Add me to the list. I want four (4) Paradise PCB's and four (4) Power Supply
PCB's.🙂 Any idea about parts and/or kits? 😕
''There are three different choices:
Calvin Buffer € 4,00 per piece (€ 8,00 for a stereo set)''
I think it's referring to the separate shunt boards.😎
The shuntboards must be possitive and neative on one board?I think it's referring to the separate shunt boards
- Group Buys
- Paradise phono stage
