Well, I hope i am covered with the ones coming from you, plus the new batch i ordered from Conrad🙂
what is the target hfe?
are we matching total hfe per quad? top against bottom? for both sections?
@ pdul the Fairchild TDS lists the -40 group hfe as 250 ~ 630, so yours are just on the low end of the scale.
I match the input stage, top and bottom and the mirrors, top and bottom. Absolute hfe is uncritical so even a 300/300 match is fine. 10% match in each functional section is good enough too. I can tell you even something : Low hfe ones often have less noise and higher early voltae so high hfe is not the only parameter.
Read this and start to understand :http://www.essex.ac.uk/csee/research/audio_lab/malcolmspubdocs/J7 Fuzzy distortion.pdf
Thanks for making this clear, Joachim. So a close match is better than searching for high hfe - lesson learned 🙂
- Group Buys
- Paradise phono stage
