I didn't want to muddle up the paradise build thread with dumb new guy questions, so Ithought to start a new thread. I have built all of my gear but it is point to point tube stuff. This is my first pcb construction and I have some questions. Should the leds be mounted flush or should they stick up? The short lead of the led goes to the +sign?
Solder is applied from the back side of the board?
Can you suggest a youtube tutorial on pcb soldering?
I have the transistors measured and matched just choking on putting the solder to her.
I have a selection of conical tips and a good solder station as well as a solder reflow.
Thanks in advance, Bill
