Panasonic WM-62 or WM-66 instead of WM-61?
The 62 should work...it's a discontinued model, but Panasonic recommends using the 64 in it's place, and the 64 data looks fine:
http://www.panasonic.com/industrial/components/pdf/em02_wm64_c_k_bc_bk_dne.pdf
The 66 is another matter. It's a noise cancelling mic and doesn't look to be appropriate:
http://www.panasonic.com/industrial/components/pdf/em08_wm66_ec103_d103_dc103_67_d103_dne.pdf
The WM62 may be physically smaller and more difficult to work with.
Here's the datasheet to the WM61, so you can compare specs. etc:
http://www.panasonic.com/industrial/components/pdf/em06_wm61_a_b_dne.pdf
