In the last time I had the opportunity to examine and upgrade a Panasonic UB450. When one look at this device and know its price in shop, then one`s first thought hearing about upgrading it, is: what to upgrade to this cheap device?
Indeed, this device is a very cheap media player, meant to playback discs, streaming over the network, as playback for media files through the device USB port. The optical device is a cheap whole plastic item. Working well, but a little bit noisy. The chassis is made of a less 1mm thickness steel plate, with a cheap, whole plastic front panel. The whole device it consists of a small low-profile box.
Inside we find a small one main board, with all of necessary chips on it. A glued heatsink partially placed over the main processor as over the memory chips in central area of the board. No any analogue section for audio. Also, much unnecessary these days an such dedicated analogue audio section, when one is largely using video processors to get analogue audio quality out, or other similar solutions. A local analogue audio section it has its own advantages when about outputted quality sound, but in this case for cost effectiveness reasons, it was decided not to be implemented.
The power supply of the player is an external one, a small compact SMPS type, to be connected directly to the outlet.
Well, this cheap device, and out of the box, is indeed capable of a very good picture quality. It was my first surprise in using it. I own and use myself an UB9000. Comparing UB450 with UB9000 was very easy, and UB9000 is indeed surpassed by this new and cheap UB450. Not only similar picture quality out of the stock UB450, compared with an upgraded UB9000, but a much better user interface as well for UB450. Very fast Menu navigation. Much user-friendly interface. No hanging or freezing, as very annoying it happen in case of UB9000. Very fast loading and ready to playback for files residing on a USB stick. Lot of GB getting ready for use in around a second, while one should wait many teens of seconds for the same to happen on an UB9000. I have noted especially about the HDR functionality on this UB450. It really makes a difference, is very obvious and improving a lot the picture quality. One realises indeed what mean HDR improvement when using this UB450 device.
Initially I was myself sceptical about the results of an upgrade for a such cheap item. And what to upgrade more, for a such picture quality out of a stock UB450?
Then I proceeded to a close examination of the electronic design, firstly targeting to adapt the power supply approach for the use of an LPS. Mainly, it was about replacing the DC 12v main rail, provided by the original small SMPS box, with a linear analogue 12vDC solution. Not difficult task also.
Proceeding accordingly, and after using an improvised LPS circuit (see picture), I had another pleasant surprise. The use of a linear power supply it confirmed once more that it can improve a lot even an original high video quality. However, one cannot realise this difference, but only after an LPS it is providing power instead of an SMPS to the targeted digital circuitry or device. The difference is there, is obvious, and is pleasant. All pictures’ parameters are improved: brightness, contrast, colour, tonal range, finer details, noises level. Everything it get in fact better.
Then I decided that this upgrade is really worthy and it need an more professional approach. So, I designed an LPS which it will fit into the available place inside the small enclosure. I was initially appreciating that the heat generating by a such lower power LPS for this device, it may not represent an issue. Thinking it will be enough to dissipate the eventual heat through the metal parts around, bottom of the chassis and the tiny steel plate cover, with a passive ventilation. Well, I was enough wrong about the heat. Even low amount heat, the heatsink it could not be that big, and the dissipation effectiveness it was not good through the chassis bottom, and the cover. I improved the thermal contact, but not enough either. The inside temperature was rising against 60°C with passive ventilation. In the end I realised that the best ventilation solution is using a fan to force the air out of the small enclosure. The enclosure it was originally provided with ventilation holes, which it could be used for this forced ventilation approach. Choosing the right silent fan, powering it from an added dedicated regulator on LPS board. A large hole (fan dimension/diameter) should be carved into the bottom of the chassis, for the fan to effectively exhaust the hot air from inside, while fresh air coming through the original ventilation holes. This solution it was effective indeed, and the inside temperature went down to 45°. Reasonable result, and nothing it affected the original shape and visual aspect of the player. The fan is running fully silent, mounted on a good dumping material. I have also mounted new and higher dumping feet for the chassis.
I have placed on the LPS board also circuits for the two oscillators (upgrade) for the main processor and the video processor chip. The original clocking approach is using resonators connected to the inbuild clock generators inside the main processor and video chip. Classical cheap clocking design solution.
Well, this LPS placed inside the device enclosure it should be powered by a transformer which very obviously it has no place inside such small enclosure. An external nice and professional enclosure solution had to be adopted. HF and DC blocking filtering cells are also added to this external power solution.
For such a cheap tiny device, a such expensive LPS solution! Well, in the end I appreciated as worthy. The improvement gain in quality for picture and digital sound is remarkably high. In the end, the whole upgrade cost it exceeds by far the device selling price… However, as overall costs (device + upgrades) it still yet be lower than upgrading another type of player, as UB9000 or whatever. And the quality out of UB450, it exceeds what is possible being obtaining from a more expensive device (upgraded).
The overall conclusion: everything it worth for the final results.
Yes, it is possible for UB820 as well. There is more available place, but I think it may be necessary an external box for the transformer of the LPS, as the chassis is too low profile to allow an transformer inside. However, I can see an eventuality to even mount an transformer inside. A closer look is necessary to consider better on this eventuality...
The choosing of the power supply parameters is made based on a detailed analyse of the original power system, measurements and appreciations of the power requirements of the existent hardware, and even appreciating measures to minimise the eventual risks of implementing a new power system. Not all the original power system it can be substituted, but part of it can be. The more of the original power supply circuitries are replaced by linear power, the better results in the end. Then, it follow the designing of the new power supply, based on the previous analyse results.
For clocking system is a similar researching approach. Finding out where are the clocking components placed, the type of it, how it are powered (if the case), and the parameters of the clock signal. Also, important is finding the right point for injecting the new clock signal, for the processors to work properly. Here is about a "calculating" guessing, and the chances for success it are 50%. However, this particular trial is not damaging for anything. Only a 50% chance to work from the first trial. Then a second trial it solve the problem.
Well, all together it mean quite a work, I can say...
As a principle, the LPS (rectifier bridge, regulators and filtering) it is better to have shortest possible DC path (transportation lines) to the circuits it will provide power to. As it is not always possible to have the big transformer in the same place, or on same PCB with the DC regulators and filters (this case), I chosen to mount only the transformer in an external box. In this approach it is transported (from external unit to the LPS board mounted inside the player), only the AC power. The AC line is less affected by the cable length than the DC lines are, and so it is the most energy efficiently to do it. Of course, it can be done so to place everything in one external box, and connect the DC lines to the small device. If is only about one DC line, then it could be well done in this way. Also this it was the original powering approach (a small SMPS box connected to outlet, and an 12v DC output to be connected to the player). As my LPS it deliver more than one DC line to the main board, the cable become more complicated, more expensive (shielding and larger sections as well), and the susceptibility for getting noisy DC lines is much bigger. Such scenario/design is to be avoided as much as possible. In extreme cases, very short DC lines/cables it have to be adopted.
When about this this UB450, a different connector for AC power input was mounted, because the original one was not possible to adapt it (particular PCB design in this case).
I’ve been using a slightly modified UB820 as a 4K UHD player to good effect with my LG C2 77” OLED for about 20 months.
Recently it has trouble reading discs and stops and stutters even if playing. Was looking on what to “upgrade” to and this thread started me thinking in different ways.
First, the UB450 is a UK/EU specific model. The UB420 available in the US has a detachable AC cord. Looking at other available Panasonic players, the UB154 appears comparable to the UB450 with the same 12VDC external wall wart power supply. It has HDR 10+capability and is only lacking Dolby Vision. A bargain at only $177.
I still had a linear 12VDC 5A Paul Hines based power supply I put together years ago for an old MAC mini music server. So I went ahead and purchased the UB154 from Amazon to try out. And easy to return if it didn’t pan out.
TLDR: the combo really surprised me on how good the picture quality is! Helped a little to turn off the OLED’s internal WiFi too.
Since I view only discs from the player (no OTA or internet streaming), this basic setup will do me fine for a good long time. Plus it reads discs and other functions faster. And my larger hand friendly UB820 remote works fine.
Thank you Coris for starting this thread!
You are welcome with more about your experiences with the new device. If you have already an 12v DC PSU, then you can direct connect it. Replacing the original SMPS with an LPS it is already a big improvement step. My LPS for UB450 it also include the clock system upgrade for UB450, replacing the original resonators for main processor and MediaTek processor, with oscillators powered by ultra low noise ESS regulator.
I have not yet worked on UB820, but I suspect these devices may use the same or very similar chipsets (processors), so it may not be a surprise that the picture is of similar high quality in these last models. In the end it is about how good the data (digital signals) are processed, with better speed and improved memory capacities, as how the internal software algorithms er improved. I have noticed how nice HDR is working on this model. It have a very big impact over picture quality indeed., comparing it with another older models. Also the menu in this device is very responsive, much more user friendly, than in UB9000. All is smooth and fast, nothing is freezing, the reading of the USB stick is very fast (lot of GB of files are ready for playback in around a second). The UB450 It is indeed a very good surprise all point of view, especially when is about a so cheap device. The upgrades it only improve everything, but in this case the upgrades cost is higher than the device price itself... More about this device in a dedicated thread (soon).
UB450 has Mediatek (MTK) soc, firmware structure is total diff than UBx20. Thx for review
- Digital Source
- Panasonic UB450 - discussions, upgrades
