I am in a middle of repairing of Panansonic Projector LB-50. While repairing of Projector Ballast I found a mosfet K3934 (three pin). I have not been to find a data for this component. Any one having any information regarding equivalent of this component please reply
Kashif
Kashif
k3934 datasheet
try here
www.semicon.toshiba.co.jp/docs/datasheet/en/Transistor/2SK3934_en_datasheet_061106.pdf
try here
k3934
i think it might be a 2sk3934..toshiba website has the datasheets
or you can try here
http://www.datasheetcatalog.com/datasheets_pdf/2/S/K/3/2SK3934.shtml
best of luck
if i remember right there was some sort of ballast modification kit made by panasonic..as the ballast kept blowing up lamps.
i shall try to fish out the part numbers later
or you can try here
best of luck
