Panasonic FC caps have magnetic leads
I just discovered this when I put one near a screwdriver.
Is this normal? I've always read that magnetic leads were bad, but in the other hand, everyone here seems to like FC caps 😕
Hmm... shouldn't because the leads are supposed to be tinned copper. I am thinking maybe there is charge in the capacitor so thats why it reacted to a magnetised screw driver?
If you short the leads together, you'll see that the leads are still magnetic.
Static charge does not create a magnetic field, only an electric field.
Does it even leak when the cap is open circuit?
Yes, but the leakage very very small. I saw the datasheet and its around 3uA. This is also why the charge in a capacitor is not indefinite. The main leakage is due to the dieletric (the insulation) used between the +ve and -ve plates. IF you have a perfect dielectric, no electrons can migrate over. But in reality, this is not possible.
