I have a pair of working single-ended audio transformers that I removed from a Tandberg 74B tape deck.
The deck used single EL84s in each output. It was rated for 3 watts/channel.
The SAMS data show that these have 5600 ohm primaries with 3-4 ohm secondaries, or about 11K with 8 ohms.
There is also an unused tap on the primary side with the ratio of 44/56, which might make for a screen tap and higher output with reduced distortion.
$50 for the pair.
If interested, please send me an e-mail. Thanks.
$50 for the pair.
