Pair of SB Audience NERO 6" Neodymium Pro Midrange Drivers
I have a used pair of SB Audience's BEST Midrange (NERO Line) for sale.
Retail is $271.95 CAD EACH ($543.90 CAD + Taxes per pair) at Solen.ca currently
https://www.solen.ca/en/products/nero-6mrn150d-16cm-paper-cone-pro-midrange-8ohm
It is the NERO 6MRN150D Neodymium model
Driver Features:
6" (162.7mm) Paper Cone Neodymium Pro Midrange
98dB / watt Sensitivity
150 Watts Continuous / 300 Watts Peak
Rated range 200 -10,600 (more realistically I have measured it pretty flat from 350 - 3.5kHz)
8 OHM Features Proprietary cone paper material with graphite
Flat foam surround for best midrange reproduction
High grade (Powerful - BL 13) neodymium magnet
Shorting ring in motor system for reduced distortion
CCAW voice coil for reduced moving mass
Minimum damping fiber glass voice coil former
Cast aluminium chassis
Condition-wise its an 8 overall
Paper / graphite cone / flat foam surround rated a 9
A few marks on cast frame / Mounting screw holes (See photos for reference)
Selling this PAIR for $169.95 USD with FREE Shipping in Canada & US
