Paia Fatman Pot replacements
arjun said:
im kinda new to all this.. could you run me through exactly what your talking about?
Sorry, I actually can't be much more help. I can generally describe the technique: basically, you take the scratchy pot out of the signal path by using it to drive the gain of a transconductance op amp instead. Unfortunately, the only OTA I'm 100% sure would work well in the 9V battery world of guitar pedals is the CA3080, and it is obsolete. I don't know of a replacement, although I'm sure somebody makes an OTA that will work, maybe not as spectacularly as the CA3080 with its +/- 2V minimum supply.
