For UK people ONLY!!! Not sending gear overseas.
ALL drivers have been throughly tested and are 100% fully working.
2x Fane Studio 8M, 8 ohm versions, cast frame,vented pole piece, 100w rms, 80hz-8khz,SPL 101db at 1W/1m.
£50 the pair o.v.n.o
In very good condition.
2x Fane Studio 8M, 16 ohm versions, cast frame,vented pole piece,100w rms,80hz-8khz,SPL 101db at 1W/1m.
More info here: http://img176.imageshack.us/img176/454/fanestudio8mls4.jpg
2x Fane twin cone fullrange drivers, 12 inch, 16 ohms, 75w rms. Unsure of the model, as says nothing on there.
Both cast frames though and large magnets.
No vented pole piece, but dust cap is the cloth type.
In good condition.
They would suit guitar/keyboard combo cabs or fullrange hifi projects.
£30 the pair o.n.o
A pair of unloaded[ empty speaker cabs] that take a 12 inch driver and square piezo horn.
Made of 18mm MDF and painted. Twin ported.
Also have small metal bar handles and dual jack inputs and metal corners.
In good condition.
£35 the pair o.v.n.o
1x Selenium D205ti 1" Titanium Horn Driver
In excellent working condition in it's original packaging.
Only been tried out once for a project that had never happened due to running out of money.
The D205TI is a cost effective high frequency compression driver utilizing a 1" throat, 40 micron thick titanium diaphragm, and 2" Kapton voice coil.
High sensitivity, low distortion, and smooth frequency response are the hallmarks of this driver.
Ferrofluid cooling reduces heat built up.
Produces consistent results even with demanding usage.
The front plate uses of standard 1" (25 mm) throat 2-bolt or 3-bolt on horn lenses.
Power handling: 75 watts RMS/100 watts max
Voice coil diameter: 2 inch
Impedance: 8 ohms
Frequency response: 800-18,000 Hz
SPL: 108 dB 1W/1m
Magnet weight: 34 oz.
Dimensions: diameter: 5-5/16", depth: 2-3/8" * Net weight: 5-3/4 lbs.
MUST BE USED WITH A CROSSOVER MINIMUM 800HZ.
Will NOT refund money if someone is stupid enough to use it without a crossover of minimum 800hz.
£25 o.v.n.o
2x High quality 2 way crossover 6khz, 12dB/18dB Slope, 8 Ohms.
Screw box for input,HF and LF connections.
* Type: Two Way Crossover
* Frequency: 6KHz
* Slope: 12dB/octave LF, 18db/octave HF
* Impedance: 8 ohms
* Long Term Power Handling: 250W RMS
* Short Term Power Handling: 500W RMS
* Dimensions: 118 x 105 x 38mm high
* Insertion loss better than 0.4dB, Crossover point within +/-10% of stated value.
A two way crossover seperates the low and high frequencies to LF and HF respectively. This results in better sound quality and is essential to protect the HF driver.
£20 the pair, o.v.n.o
Everything except the unloaded cabs can be posted.
PM me for pics if seriouslly interested.
NO time wasters.
In good condition.
£30 the pair o.n.o
In good condition.
Impedance: 8 ohms
SPL: 108 dB 1W/1m
£25 o.v.n.o
* Frequency: 6KHz
* Impedance: 8 ohms
NO time wasters.
