Hi, my PA amplifier has the double watts RMS needed for my speakers, so I put the gain knob -3db. I started using Equalizer APO as a DSP for my sound system, and I want to have the knobs on the amplifier all the way up and put the -3db gain in the pc. But it's not the same, I tried to match the volume, and I ended up putting -6db to -10db in equalizer apo, someone can explain why?
How much -DB I put on Equalizer APO to match the -3db on the PA amplifier?
Thanks...
Thanks...
Say Your amp outputs 100W with a 2V signal. If You feed it with a 1V signal, it will output -3dB. What's Your 0dB PC output signal ? 1V 2V 5V ?
You have to set the -3dB on the PC but then use the main volume to match the 1V signal. If the amp has a VU it's simpler. Adjust the volume until the -3dB led lights.
Boas, é Português??
Eu tenho amplificador de som PA, só tem mesmo os botões dos DB, e a parte de trás do amplificador, onde uso 1V de entrada de sinal. uso uma focusrite scarlett solo como placa de som. Eu uso o (Equalizer APO) como crossover, equalizador, etc...O problema é que os (-3db) no botão do amplificador não equivale aos (-3db) no pré amplificador do Equalizer APO, no qual tenho colocado entre (-6db a -10db). Secalhar o Equalizer APO utiliza uma medição de DB diferente.
Good, is it Portuguese ??
I have a PA amplifier, I only have the DB buttons, and the back of the amplifier, where I use 1V signal input. I use a scarlett solo focusrite as a sound card. I use (Equalizer APO) as a crossover, equalizer, etc ... The problem is that the (-3db) on the amplifier knob is not equivalent to the (-3db) on the Equalizer APO preamp, which I have placed between (- 6db to -10db). Underlying the Equalizer APO uses a different DB measurement.
Hello jon146 and welcome as a new member. Only post in English or include a translation please. As a rule in this forum we all do. More posts in another language only will not pass.
Why? What are you trying to achieve?Hi, my PA amplifier has the double watts RMS needed for my speakers, so I put the gain knob -3db.
"-3dB" only affects Gain, not maximum output Power, by any means.
Please state Amplifier Brand and Model; a direct link to user manual would be even better.
Same question as above.I started using Equalizer APO as a DSP for my sound system, and I want to have the knobs on the amplifier all the way up and put the -3db gain in the pc.
Hard to answer unless we clarify the doubts above.But it's not the same, I tried to match the volume, and I ended up putting -6db to -10db in equalizer apo, someone can explain why?
In any case, matching volume by ear is quite inaccurate.
E Bem Vindo no Fórum!!! 🙂
- PC Based
- PA Amplifier and Equalizer APO gain knob do not match?
