P-P Load Resistance vs AB1 vs AB2
Good evening and a Happy New Year to all,
I am looking at a 2E26 data sheet which has parameters for class AB2 audio service. Given the same plate voltage and screen voltage, will the P-P Load Resistance change for class AB1?
Ray
Just by eyeballing a load line on the curves for G2=160V, I guess the best you can do in class AB1 is about 17~18W into 14K, or about 24~25W into 10K with G2=200V. Both estimates assume 400V on the anodes. Why not use class AB2? Tube linearity is no worse, and grid drive is easy with MOSFET source followers.
Ray
The load will change significantly. Look at the plate characteristic. The vGK= 0 plate current isn't above 150mA. It's much higher when going AB2 and that means the load resistance decreases.
This type is a Class C RF type that was designed to have a very low static plate current with vGK= 0 to reduce the bias required to pit it into Class C. As such, you're not gonna get much output if you stick with AB1.
You can get 50W and more from types like the TV HD finals while staying in Class AB1. There's also no telling what these sound like, and may need help from local + gNFB to sound really good. That's not the cae with TV HD types. There are better audio finals.
