I couldn`t found the answer using search engine, sorry if it has been cowered before. How can I post the PCB file made using P-CAD 2001 to the forum? Should It be transfered in some other format?
Thanks!
Thanks!
If you put the files into a ziped folder you should be able to attach the file to your post (as long as it is not too big). If however, you just mean an image created from the file, I think both JPEG and GIF formats can be attached directly without needing to be put in a zip.
