P Audio BM-8CXA question
Hello girls and boys...
Need an advice or "how to"...
I have a pair of P Audio BM-8CXA drivers.
Would like to remove the back of the tweeter for mounting into an open baffle project i am working on currently.
Can someone tell me what to expect under the cap of the backside of the tweeter?
I know i have 4 screws to remove but what is holding the tweeter coil with the dome there and how to secure it when i remove the backside of the tweeter part of the driver....
Would love to know what i have to be careful on before going into this ..
thank you
Thank you for the video link....
... it is probably typical but i never took appart one... so i have to ask at least ����
Will check the video a bit later when kids are asleep....
I had an idea to maybe cut a hole in each endcap and with thus to open the backside....
Have to check the video
mattstat - first video seems to be showing exactly how the coil is placed on my driver... at least on some iterations of that driver... problem is i have a same type of the driver with different connecting spots ... so i asume it is the same internally related coil and diaphragm but that the cap is actually fixing that in place...
either way - it is very clear on that video that it should not be a to much of a problem to dismount the backside and check it out... if moderately careful, seems to me, i will be reasonably safe not to damage anything....
great help - thank you
Crimes, I would not so much describe that as "modifying a compression driver" as outright butchery!
It is difficult to see that operating as a compression driver, and I can only imagine how soon fatigue related cracking/ tears can be expected to occur in what little remains of the suspension.
Why would you do that to a driver, and then put a horn on the front?
That video definitely shows a rather aggressive approach, but some people like to experiment and figure out how things work. An experience is often a better teacher than theories and speculation. And in this case, it also showed a different way diaphragms can mount, which was useful to this discussion.
Since most compression drivers are used way below their power ratings in home audio, it may do what he wanted over a limited use range. It's certainly going to be different than the original designer intended, but I think that was the point.
The efficiency of that driver is great because of the horn, if you open the chamber at the back, the sound you get at the back will be much weaker than the one at the front from the horn. And the parameters of the driver will also change.
