There were a couple of posts in the "NE5532......misunderstood" thread, regarding overload in RIAA stages. So we started a new thread for this.
I will just copy some bits from the posts to show where it was headed. Will put up a circuit a little while later.
.............I just completed a two stage passive equalised RIAA phono amp. All opamps are on sockets.
The input opamp is configured for a gain of about 31 .
The passive 75uS eq follows and is buffered by a unity gain opamp. Then comes the passive 3180uS and 318uS filter and followed by an opamp with a gain of about 10.
The last opamp is a Burr Brown OPA2134.
......................don't you think you'll get better S/N if the mid stage has some gain
.......................I was looking at the overload factor when I picked the configuration. I might be wrong of course.
The input stage is designed to accept about 400mV peak that seems to be the max output one can expect in the worst case ( noisy ) scenario from a MM cartridge.
The second opamp will have to handle this full signal if it occurs at anything less than about 2kHz. But I am not sure of the noise spectrum of surface noise . I was just trying to be extra careful.
In practice , with average albums , it might be possible to have gain here without encountering any overload problems on spiky noise. Spiky noise basically must be HF trash. But what about LF content in it ? Something like a drum . Large transient with decaying LF signals.
On second thought , that sounds wrong!
Can you and other RIAA experts comment on this - overload due to non musical signals ?
...............Hi Ashok
This is way out of topic and we should probably rather move it to a new thread if anyone else shows some interest.
But the LF is still some 20db below your 12v limit, right? Anyway, i didn't realise you expect 400mV peaks, that's rather cautious, isn't it? How do you estimate the S/N in everyday use?
I haven't tried a split riaa with opamps for almost 20 years, maybe the time has finally come One potential issue is the need for separate regulators for each opamp - i find this really determines the absolute transparency of the cascade.
Have to run. More later.
Cheers
Cheers
Here is the circuit diagram
The Circuit diagram is attached.
I have concluded that the maximum possible signal that can come out of a MM cartridge under very noisy conditions is 400mV peak. That is about 283mV rms. This figure is based on figures that I have seen on the web and the overload limit on many commercial preamps being 250mV. We are assuming that the cartridge produces 1mV/cm/sec.
So the input stage gain was set at 31. The value of R3 is 30K and not 27K as in the ckt diagram. This permits the input stage to handle the worst case input signal without clipping. In a tube stage this overload limit is 'much' higher and possibly why they sound cleaner on noisy surfaces.
Using discrete components it is probably easier to design an input stage that will outperform a chip implementation.
Considering 'noise' and its spectra. I vaguely remember reading that very high amplitudes produced on playback of old discs lies around the 5Khz region.
Can this under any condition extend to below 2kHz ?
What is the spectrum of this noise? How high are the harmonics ?
Like Analog_sa suggested the other frequencies must be quite low . Looking at a noise spike , it might look like it could be less than
the main spike by at least 5 times ( 20%). Is that a realistic value and what would be the lowest frequency?
Listening to some loud clicks off the disc it does seem to have some reasonably low frequency content.
Has anyone ever looked at this ?
It would be interesting to know how much gain the second opamp can have without danger of clipping noise spikes. The 75uS filter should be cutting down the amplitude of the spike .
Can the phono experts shed light on this issue.
Thanks.
Ashok.
Thanks.
Ashok.
"The input stage is designed to accept about 400mV peak that seems to be the max output one can expect in the worst case ( noisy ) scenario from a MM cartridge."
Per J.L.Hood "Art of Linear Electronics" Ch 9, the maximum out pou available from a MM cartridge is 19mV RMS. Unless I misunderstood something, you are amply covered if you can handle 400mV. Hood goes on to say that the resulting output to the power amp needs to be .77V RMS with the result that +/-15V rails will be adequate.
Don't know if this helps.
Noise spikes.
Hi Sam,
You are right about the musical signal levels. We are refering to signals generated when you have bad clicks and pops due to dust and surface imperfections .
You will find that people have studied this and found noise spikes to be several times higher than musical signals. I even came across a graph showing this , somewhere on the net. I will search it out again.
To quote approximately : ' loud noise pulses clip in the input stage causing audible artifacts to be generated within the audio range and degrading the sound that one hears. This is why some preamps sound fine with noisy surfaces and others make the same recordings un-listenable.'
So I am trying to find if someone has done an analysis on this and how it can be used to optimise the circuit gain.
Ashok.
Hi Sam,
Ashok.
NAD-PP1 phono preamp specs
Here are the NAD-PP1 phono stage specs:
Tech specs
Input impedance: 47 kohm + 220 pF
Input sensitivity for 200 mV out: 2,5 mV
Signal/noise ratio: 78 dB (weighted A) - 72 (unweighted)
Input overload at 20 Hz: 55 mV
Input overload at 1 kHz: 63 mV
Input overload at 20 kHz: 580 mV
THD (20-20k Hz): 0.04 %
RIAA accuracy: +/- 0.5 dB
As you can see the HF overload is very high .
The actual overload wrt to freq also depends on the kind of equalisation we use.
The kind of overload figures you see here are usually in preamps with the equalisation networks in the feedback loop. The circuit shown in an earlier post has no frequency dependant feedback.
Thus it's overload characteristic is different.
There are pro's and con's for the different schemes that we can implement. Picking one and perfecting it is tough! Personally I would like to try out all the different schemes at my place so that the ONLY variable is the circuit . Before I start doing that it would be good to discuss this and see what others have to say. I can't obviously try all the schemes .
Ashok.
Tech specs
Ashok.
Noise etc.
Analog_sa...
Yes the LF will be quite safe even if stage two had gain. In the absence of any info regarding the spectrum of the noise , we can assume that the spike does have a fundamental of over 5Khz with LF content that is at least -10 db wrt to the peak.
Additionally the mid band typically needs less overload margin and 100mV seems to be quite good. So making a rough guess we could get away with a gain of about x4 in the second amp.
The input stage should have a S/N of about 67.5db with a 5mv input signal. All noise calculations are for flat bandwidth .
At the second amp the signal to Noise ratio should drop slightly. My rough calculation shows less than 0.5db.
So the S/N in stage two is now 67db .
The gain in the second stage will only affect the SN in the following stage. Here the current noise will have an affect due to the high source impedance. But I am using an OPA2134 here which has a current noise of 3fA(Hz)^0.5. So it turns out to be quite low. Additionally it also has a voltage noise that is 5.5 db below the AD826.
AD826 voltage noise is 15nV(Hz)^0.5
OPA2134 voltage noise is 8nV(Hz)^0.5
NE5532 voltag enoise is 5nV(Hz)^0.5
So we end up with about the same S/N ratio ( 67.3db) in stage 3.
By having gain in stage two we will hardly improve upon this as the S/N seems to be largely determined by the first stage.
Taking the equilization into consideration we will get some more improvement in noise. I read something about this recently and it said that the RIAA equilization only improved S/N by less than 3db. So we are close to 70db S/N.
With the NE5532 we will get a 9.5db improvement in noise - but what about the sound quality we heard with the AD826 ?
i practice I can hear his only when I put my ear against the speaker. From a meter away I can't hear any hiss. So practically the S/N is OK. On my measured noise spectrum the noise above 1Khz drops away pretty rapidly.
An OPA2134 will give a better S/N by about 5.5db. I must try this combination. The current noise is also very low. The last time I tried it , the AD826 sounded better than the OPA2134 in a straight forward buffer amp.
Does all this make sense? My head is spinning. Must settle down with a drink and have dinner and go to sleep.
Analog_sa...
Hi Ashok
Apparently there are other opinions as well. If you look at the Hagerman Buggle you may notice the gain structure is x11,x11,x10 and the low-frequency correction comes first.
No idea if this sounds better or not but it's certainly easy to test. What worries me though is that in your curcuit the mid opamp is only there to allow a split RIAA. The question is then if splitting warrants the inclusion of a dummy stage.
regards
regards
Re: Here is the circuit diagram
Konnichiwa,
This assumption may be reasonable as average, but not as maximu value. The "loudest" MM Pickups I know come in around 2mV/cm/sec and can trace at 300Hz (HiFi News Test Record) a track with +18db above 5cm/sec. This kind of level covers more or less the 300Hz to 3KHz band.
With MC Catridges there is much lower level, but this may be stepped up using (for example) a wideband transformer. Let's use an example of 0.1mV/cm/sec and a +26db stepup, giving also 2mV/cm/sec. Unlike MM Pickups, MC pickups can genertae high output way into the supersonic range. usually tracking is not an issue at higher frequencies, so very sharp spikes (dustparticles) may produce very high levels with a very substantial slew rate.
Any which way, we can assume around 80mV (RMS) @ 300Hz...3KHz from the cartridge, AT least and the same sort of level and more via an MC Pickup and suitable stepup with a lot more high frequency content.
If we amplify these 80mV by 30db we get around 2.5V RMS after the first Op-Amp. A normal Op-Amp on +/-12V rails can produce around 7V RMS into easy loads. If we have only the 75uS timeconstant ahead of the second stage the gain should be limited to under 10db to make sure no clipping occurs under normal conditions.
I personally prefer by far the use of an active, feedback RIAA EQ with solid state components, simply becuase headroom problems become near irelevant as well as the reduction of slew rate issues.
For MC pickups it may be interesting to use a pair of nice Op-Amp's in Shunt Feedback mode, say a AD797 or AD811 in the input with the 3180/318uS EQ in the feedbacl loop, inverting connection and then have the 75/3.18uS EQ in the second Op-Amp's feedback loop, maybe a nice FET type or another AD811/AD797....
Sayonara
Konnichiwa,
ashok said:We are assuming that the cartridge produces 1mV/cm/sec.
ashok said:It would be interesting to know how much gain the second opamp can have without danger of clipping noise spikes.
Sayonara
care to explain your logic in choosing passive eq?
http://www.diyaudio.com/forums/showthread.php?postid=327697#post327697
S/N ratio
9.5 db improvement by using the NE5532???
If I remember right, then the NE5532 is a fully BJT based
design and has remarkable input currents and with this
also higher input noise currents..... can't find that xxxx data sheet right now... So you will only get real low noise with that OP amp if you use very low impedances. But then NE 5532/NE5534 is hard to beat in noise.
I would prefer the AD8065 (or dual AD8066) for the first stage.
It offers:
7nV/Hz^0.5
AND !!
0.6 fA/Hz^0.5
If you want to use some cheap standard which is easily available everywhere then you might better use the NE 5534 (instead of NE5532) in the first stage. At this gain you will not have issues with stability.
With such BJT OP amps I would propose to reduce the resistors of the feedback network in the first stage by factor ten for this OP amp. The OP amp can easily drive this.
Input resistor of 47kOhm should not be reduced, otherwise
the load impedance for the MM would not be what they are designed for. But at this position the high resistance will not cause that much noise, because the internal MM-resistance is in parallel.
Bye
Markus
It offers:
7nV/Hz^0.5
AND !!
0.6 fA/Hz^0.5
Bye
Markus
5534 better than told
...I found the data sheets of NE5534.
The current noise is stated around 0.6pA/Hz^0.5!
Also the low frequency current noise is fine with 2.6pA/Hz^0.5!
Much better than I thought.
OK, there seems to be no need to reduce the values of the
resistors. Current noise seems uncritical.
Sorry for causing confusion.
Cheers
Markus
Cheers
Markus
Eq config.
Hi JCX,
I wrote out a post yesterday about the eq but something happened and the post was deleted even before putting it up. Got quite mad about it and so decided to do rewrite later.
The input stage has the 75uS eq so that the HF overload capability of the second stage is good at HF. If we used the 3180/318 uS eq here it would not have as good an overload figure as compared to the 75uS at HF.
Having written that I think this should not be an issue because the first stage is the one that really determines overload ! That has been taken care of already.
Now we come to the S/N ratio. The max S/N ratio is determined only by the input stage. Subsequent stages will only degrade it (and of course improve a bit due to the eq filters !).
With a relatively high signal at the input of the second stage (75uS eq ) the S/N ratio will be better as compared to the signal with 3180/318uS which would be 20db lower in level.
With opamps like the AD829 with a noise voltage of 2nVrtHz this may not be an issue.
The second stage could possibly have the 3180/318 eq in its feedback loop. The HF will not roll of till unity gain as it will be in the case of the 'all at one go' feedback network.
This would however mean a frequency dependent feedback network which we are trying to avoid.
I am currently working on a board with active/passive eq switchable. That way I can see if there is really an audible difference (with modern opamps).
The other option that I am also working on is an 'all passive at one go' filter after the first stage . I need to work out the details and determine if it will load the first stage. Capacitors will have to be as large as possible to keep impedance down for the next stage and to overcome stray caps.
Has anyone already done this?
This has to be done. Like the difference in sound between the NE5532 and OPA2134 is really heard only by practical implementation, I guess we have to build the circuits to determine their sonic capabilities.
Another doubt. Did the NE5532 sound different from the AD826 or OPA2134 because of the large difference in the input bias current flowing through the cartridge coils ? This must be causing a dc offset in the operating point of the cartridge. The magnetic flux will have an offset operating point.
I have no coupling capacitor at the input. Where ever possible I try to tolerate dc offsets and avoid capacitor coupling.
In another phono stage with 0 volts dc at the input a film type coupling cap very audibly degraded the sound. After that I try to avoid use of such caps as far as possible - and we aren't even talking about electrolytic caps !
Cheers.
Ashok.
Hi JCX,
Cheers.
Ashok.
No. The input bias current effect on the cart is negligible. As i don't use MM carts there is always an intermidiate stage before the first opamp and they still sound different.
Some more opamps.
I tried the LM833 and the LF353 yesterday.
The LM833 sounds surprisingly good. Closer to the OPA2134 than the NE5532.
The LF353 sounded light in the bass . It took away the foot tapping quality from the OPA2134. This is more prominent in the AD826. I am waiting for my AD829's.
In order of preferance ( in the RIAA amp) I like the op amps as follows :
AD826
OPA2134
NE5532/LM833
LF353
Wonder if I should check out the TLO72 and TLO82 ??
Cheers.
AD826
OPA2134
NE5532/LM833
LF353
Cheers.
AD829
Hi Ashok!
...checked through the data sheet of AD829...
This fancy OP amp might become one of my best friends
when I need much gain for small signals!!!
THX for the hint!
Bye
Markus
Hi Ashok!
THX for the hint!
Bye
Markus
Other configurations.
I have been trying some other configurations ( with R and C in the -ve feedback loop) and find that the small resistor in the -ve input of the opamp ( going to ground or through a capacitor to ground ) affects the accuracy of the equalisation quite a bit. Keeping the eq passive ensures that the number of components that affect the equalisation is kept to a minimum.
Any thoughts on that ?
Cheers.
Cheers.
analog_sa said:Hi Ashok
regards
I have a Bugle, sounds pretty good. There was a lower end/ kit preamp shootout in AudioXpress mag some months ago, and the Bugle was the best of the bunch.. including that NAD and others that cost up to $250. Some did have some overload while testing on a test record, the Bugle didn't if I recall correctly..
AD826
OPA2134
NE5532/LM833
LF353
Cheers.
Interesting... I was looking over op amps, and came across the AD826, got some samples and tried it.. (instead of the original OPA2134's) We decided there was a definite improvement..
I'd guess the TLO's would be a step down.. but there's one way to be sure..
AD826
Never tried this one. From OPA627/637, AD8610, AD825, AD845, AD8065 my uncontested favourite is 8610. I use it with a BUF634 and NFB RIAA and there is almost zero DC at output.
Initially i didn't like the sound all that much but with a Lundahl 9206 in front it became much better than i could ever hope for op-amps.
As soon as i get some time i'll rebuild it as an all-out teflon board/bells and whistles phono wonder 🙂
this interesting thread I discover by chance.
Are there any news ?
The AD829 (dual version AD826) and the AD8610 seems to be very interesting for listening test in order to get sound character like tubes - go to
http://www.diyaudio.com/forums/anal...haracter-like-tube-phonostage-e-g-ear834.html
An important feature for me is the fact, that the AD826 uses only one gain stage (folded cascode). At most other op-amps there are two gain stages inside of the NFB-loop, for me a disadvantage in order for a good sonic quality.
Unfortunately I don't find a simplified schematic for the AD8610 - who can upload this?
http://www.diyaudio.com/forums/anal...stage-working-inverted-mode-not-find-why.html
in this case this thread is of interest:Hi Sam,
Ashok.
Yes, very old thread. I wrote up my findings about active RIAA here:-
RIAA Equalizer Amplifier Design
There may some interesting info in there.
I have just built another all active RIAA recently and I think this is the way to go if you are using op-amps. A key performance metric - especially if you don't want clicks and pops to overload the equalizer - is the overload capability. I think 20 dB or more at 20 kHz is mandatory no matter what topology you use.
The 5534 in MM all active is the quietest opamp based solution available (D. Self has long stated this and practical experience supports his conclusion). If you want quieter, you need to go for a JFET front end using a good device like a BF862 and parallel them.
Inverting mode presents a problem noise wise because of the input resistor - so that is not an optimal solution for MM. Passive/split RIAA is good for discrete where you can design for high supply rails the enough swing to ensure you wont have overload at HF. If you arrange the first stage to provide most of the gain and then EQ after that, you can tame some of the first stage noise and get a reasonable result.
- Analogue Source
- Overload considerations in RIAA preamps
