ALL YOU EVER WANTED TO KNOW BUT...
Et voila:
Stylus Type: 0.4 mil. x 0.7 mil. Elliptical Diamond Stylus Configuration.
Frequency Response: 10 Hz. - 25 kHz.
Output Voltage: 5.5 mV per channel at 1 kHz.; 5 cm./sec. peak recorded velocity. Output from each channel within 2 dB.
Channel Separation: Minimum 35dB at 1 kHz.
Tracking Force Range: 1.0 to 2.0 grams.
Mounting: Standard 1/2" (12.7mm) Mounting Centers.
Cheers,😉
Et voila:
Cheers,😉
