Output Transformers for 6L6/5881/EL34/KT66 single end
I'm pleased to introduce this high quality hand made output transformers for 6L6, 5881, EL34, 6CA7, KT66. KT77 class A single end tube amplifiers. The steel core is selected 0.35 mm annealed EI. We provided the output transformers in matched pairs. We're using this output transformers on our EL34/KT66 single end. They really achieved good sound performance specially for details and sound stage. The price is very affordable. Good for tube amp diyers.
Specification:
Model: TA-SE1
Power: 13W
Size of steel core: EI 86 x 42 mm
Primary impedance: 3.5K ohms
Secondary impedance: 0-4-8 ohms
Primary inductance: 18H
Primary current: 150 mA
Frequency Range: 26Hz-30KHz
N.W.: approx. 4.4 kg per pair
Price: US$88/pair with sided metal covers
Payment: Paypal
Shipping: Air Parcel
, need to add the rate on the price.
Twin Audio KT66/EL34 class A single end tube amplifier:
http://www.diyaudio.com/forums/twin-audio/167244-new-el34-6ca7-kt66-integrated-amplifier.html
This is the example of application of TA-SE1 output transformers on our KT66/EL34/6CA7 class A single end amp.
