Output stage completely blown during idle conditions
I decided to use a screw and nut as the aluminium I've got is really soft. I had an idea come to mind with copper plates to speed up thermal tracking and hopefully make it a bit easier to mount the transistors which would help with shortening leg length as I want to really pack these amps into an amp sandwich.
I'll see how I go. I've taken your feedback on board and will have a look.
I've done more experiments and the vbe servo does not appear to be working in the first place. Chucked in on a copper plate and it still goes thermal runaway even with good transfer to the copper plate. Mind you it does need a signal to get it going into such a state. There may be something wrong with the VBE servo transistor or I didn't correctly set it up?
Well, I guess elegance is in the eye of the beholder. A low voltage polar cap that could see rail voltage of either sign under fault so we put diodes across it to protect it, and all that just to save a few pennies... More elegant to you, less elegant to me. And yes, I realize in a commercial context (which is Self's background and it often shows) those pennies add up when you're mass producing, but this is DIY, no?
I have good news. I created a jig that looks to have helped significantly with thermal tracking. I am going to run the amp for a bit to confirm. The aluminium heat spreader is getting hot which tells me thermal transfer is actually good. So going to let it run up for a bit and see what happens. Also I measured the current draw of the unit and there does not appear to be any form of oscillation considering the amp draws around 70mA idle when at operating temp.
Ok VAS and CCS sorted. Chucked in a pair of 2SC4792/2SA1837. And wow. I'm impressed with the detail of sound its got. I might upgrade to a pair of 2SC5171/2SA1930 for the high transition frequency and better power handling capabilities. Ft=200Mhz
