If I had a triode as a voltage amp with a plate resistance of 1k ohm and load resistor of 1k ohm with no feedback wouldn't
the output impedience be 500 ohm? Now if I subsitute a mosfet
for the triode with the same 1k ohm load resistor how do I figure
the new output impedience ?
Happy holidays to all....
bob12345678
bob12345678
1) Yes.
2) If the Drain of the Mosfet is biased with 1K like the
tube was and also loaded with 1K like the tube, then
the output will be 500 ohms also.
