Output impedance of cheap players
output impedance commonly used is 1k0 to 2k0.
I don't know how typical this is.
You can check it by playing a test tone into two different load resistors.
The voltage difference into 100k and 10k can be used to estimate the output impedance.
Congli walkman(made in Korea) with recording facility,Rs 150(yes,its Rs 150):::: 13k.
Sony walkman(made in Japan),am/fm(no recording),Rs 1700:::: 15k.
both are cassete players.
cheap Chinese cdp(any cd,any format,rw too),Rs 1000.::::20k
Rs 47=$1.
Agreed. Most players will have an op-amp output followed by a resistor or two with a shunt (muting) transistor in-between. Since most op-amps will have an output impedance pretty close to a few tens of ohms, and the output Z will be pretty much dominated by the series resistor(s) placed there as part of the muting (maybe for stability too). The DV655 (pioneer) uses 200ohm resistors, so I'd reckon the output impedance is pretty close to 400 or 500 ohms.
And whoops, most players will have an output coupling capacitor - so at DC the output impedance is infinite... hahaha...
Cheers!
Clem
I apologize as I was referring to the resistive load being driven by the output op-amp. This is typically around 100Kohm.
Since there is a coupling cap prior to the output, I assumed that any prior load would be disregarded and just considered the 100Kohm load.
